[GRASS5] Re: auto-locate EPSG
Hamish
hamish_nospam at yahoo.com
Wed Apr 26 08:32:52 EDT 2006
> > the new auto-locate EPSG file isn't working for me.
> Please check:
> grep PROJSHARE include/Make/Platform.make
> PROJSHARE = /usr/local/share/proj
$ grep PROJSHARE include/Make/Platform.make
$ ls /usr/local/share/proj
ls: /usr/local/share/proj: No such file or directory
> configure now defines via hack (I didn't receive an answer how
> to do it properly) where the PROJ software is installed.
> See configure.in, line 583 ff.
> > Do I have to use --with-proj-includes= ?
> > (it has been fine without it up to now)
> Behaviour *should* not change. Apparently the
> $PROJINC
> test fails on your machine.
this one: ?
# Define share/proj/ directory for epsg code file
PROJSHARE=
if test -n "$PROJINC"; then
PROJSHARE=/usr/share/proj
else
PROJSHARE=/usr/local/share/proj
fi
is $PROJINC only set if I used --with-proj-includes ??
If not, what sets it?
Hamish
