[GRASS5] Re: auto-locate EPSG
Markus Neteler
neteler at itc.it
Wed Apr 26 06:09:17 EDT 2006
On Wed, Apr 26, 2006 at 09:55:53PM +1200, Hamish wrote:
> Hi,
> the new auto-locate EPSG file isn't working for me.
Mea culpa.
> Installed from Debian's proj package in:
> /usr/share/proj/epsg
> but clicking "Use EPSG values" points to non-existant /usr/local/share/...
> I don't see any log messages in config.log or ./configure output.
Please check:
grep PROJSHARE include/Make/Platform.make
PROJSHARE = /usr/local/share/proj
configure now defines via hack (I didn't receive an answer how
to do it properly) where the PROJ software is installed.
See configure.in, line 583 ff.
> Do I have to use --with-proj-includes= ?
> (it has been fine without it up to now)
Behaviour *should* not change. Apparently the
$PROJINC
test fails on your machine.
> ./configure
> checking for location of External PROJ.4 includes...
> checking for proj_api.h... yes
> checking External PROJ.4 version... 449
> checking for location of External PROJ.4 library...
> checking for pj_get_def in -lproj... yes
> checking for nad2bin... /usr/bin/nad2bin
It should be easy to fix, but I don't have a Debian test
environment.
Markus
