[GRASS5] 100% cpu mouse bug
Radim Blazek
radim.blazek at gmail.com
Thu Apr 27 06:12:01 EDT 2006
On 4/23/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Ideally, someone would produce a Tcl/Tk replacement for v.digit, then
> the R_get_location_* stuff can be discarded altogether (no other
> module is important enough to stand in the way of that change).
> Unfortunately, I don't think anyone other than Radim understands the
> vector API well enough to perform the necessary enhancements to
> v.{in,out}.ascii (topology support).
All you need to modify a vector is Vect_write_line(),
Vect_rewrite_line() and Vect_delete_line().
Radim
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
