[GRASS5] 100% cpu mouse bug
Hamish
hamish_nospam at yahoo.com
Thu Apr 27 07:43:04 EDT 2006
> > Ideally, someone would produce a Tcl/Tk replacement for v.digit, then
> > the R_get_location_* stuff can be discarded altogether (no other
> > module is important enough to stand in the way of that change).
> > Unfortunately, I don't think anyone other than Radim understands the
> > vector API well enough to perform the necessary enhancements to
> > v.{in,out}.ascii (topology support).
> All you need to modify a vector is Vect_write_line(),
> Vect_rewrite_line() and Vect_delete_line().
Is "v.build option=dump" a good starting point for a format to use
to describe any vector's topology?
Hamish
