[GRASS5] Proposal: RFC 1: Project Steering Committee Guidelines
Helena Mitasova hmitaso at unity.ncsu.edu
Thu Apr 27 23:32:45 EDT 2006
Markus,
you may want to add some clarification when a proposal is needed to
make a change
(it is partially implied by a section about when vote is needed, but
maybe that should be defined somewhere
at the beginning of the detailed process description - or you can
just say "When is the proposal and vote required").
How the proposal should look like?
Is a short email to developers list, as we have now enough - I hope
it is.
Regarding Radim's comments - let us try to follow the suggestions
from Markus and Frank modeled
after other projects to see whether it works for us, we can always
change it / modify later
Helena
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Apr 27, 2006, at 11:01 PM, Michael Barton wrote:
> This looks OK to me.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Markus Neteler <neteler at itc.it>
>> Date: Wed, 26 Apr 2006 21:20:26 +0200
>> To: <grass5 at grass.itc.it>, GRASS user list <grasslist at baylor.edu>
>> Subject: [GRASS5] Proposal: RFC 1: Project Steering Committee
>> Guidelines
>> Dear all,
>> to better illustrate the idea of a GRASS Project Steering
>> Committee (PSC),
>> I have drafted a document:
>>  http://mpa.itc.it/markus/grass61progman/rfc/rfc1_psc.html
>>  In CVS: rfc/RFC1_PSC.dox
>> The content is heavily inspired by the related documents from the
>> GDAL, Mapserver and Mapbender projects.
>> As stated in this document: It is desired to keep the
>> administrational
>> overhead as low as possible. However, for strategic decisions a more
>> formal approach for decisions is needed.
>> Please take a look and comment since it is a Request for Comments
>> (RFC).
>> Best regards
>>  Markus
>> Markus Neteler     <neteler itc it>       http://mpa.itc.it
>> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
>> MPBA - Predictive Models for Biol. & Environ. Data Analysis
>> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
