[GRASS5] Re: auto-locate EPSG
Markus Neteler
neteler at itc.it
Fri Apr 28 15:07:54 EDT 2006
Glynn,
I tried to add you suggestions bug autoconf gives me bad
news. Apparently I made something wrong.
Attached a opatch with your suggestions - may I ask you
to try it (at least autoconf-2.13) and then submit?
Hamish is elected beta tester for Debian :-)
thanks
Markus
On Fri, Apr 28, 2006 at 06:26:29PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > configure is autogenerated from configure.in by autoconf-2.13
> > > > So, the file configure.in has to be worked on, not configure.
> > > > Unfortunately a macro seems to be
> > > > missing for the .../share/ stuff, that's why this damn hack is needed.
> > > So do we need a LOC_ARG_WITH_SHARE macro to go with the
> > > LOC_ARG_WITH_{INC,LIB} macros? I.e.:
> > > aclocal.m4:
> > > AC_DEFUN(LOC_ARG_WITH_SHARE,[
> > > AC_ARG_WITH($1-share,
> > > LOC_PAD([ --with-$1-share=DIRS])[$2 data files are in DIRS])
> Actually, this needs to be a single directory, unless the code which
> locates the file can handle a list of directories. So:
> LOC_PAD([ --with-$1-share=DIR])[$2 data files are in DIR])
> Note that, unlike headers/libraries, where the compiler/linker has a
> default search path, the default value (the empty string) isn't much
> use; the option has to be specified explicitly for the file to be
> found.
> > > configure.in:
> > > LOC_ARG_WITH_SHARE(proj, External PROJ.4)
> > Thanks for your help! Do we probably also need to define
> > LOC_CHECK_SHARE_PATH(proj,External PROJ.4,PROJSHARE)
> Definitely; it's needed to actually read the option value.
> > LOC_CHECK_SHARE(epsg,External PROJ.4,$PROJSHARE)
> Probably a good idea, although the file isn't needed until run-time
> (AFAIK), so the test isn't critical.
> Also, if it's possible to use GRASS at all without that file, it
> should use the 4th argument to generate a warning (the default is a
> fatal error), e.g.:
> LOC_CHECK_SHARE(epsg,External PROJ.4,$PROJSHARE,[
> AC_MSG_WARN([*** Unable to locate PROJ data files.])
> > If not, I don't know how to figure out PROJSHARE (which I then need in
> > include/Make/Platform.make[.in]. If yes, would you mind to write those?
> AC_DEFUN(LOC_CHECK_SHARE_PATH,[
> AC_MSG_CHECKING(for location of $2 data files)
> case "$with_$1_share" in
> y | ye | yes | n | no)
> AC_MSG_ERROR([*** You must supply a directory to --with-$1-share.])
> esac
> AC_MSG_RESULT($with_$1_share)
> if test -n "$with_$1_share" ; then
> if test -d "$with_$1_share"; then
> $3="$$3 -I$dir"
> else
> AC_MSG_ERROR([*** $2 data directory $dir does not exist.])
> fi
> fi
> AC_DEFUN(LOC_CHECK_SHARE,[
> AC_CHECK_FILE($3/$1, [], ifelse($4,[],[
> AC_MSG_ERROR([*** Unable to locate $2 data files.])
> ], $4))
> Glynn Clements <glynn at gclements.plus.com>
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Index: configure.in
RCS file: /grassrepository/grass6/configure.in,v
retrieving revision 1.93
diff -u -r1.93 configure.in
--- configure.in 28 Apr 2006 05:40:28 -0000 1.93
+++ configure.in 28 Apr 2006 19:06:02 -0000
@@ -555,6 +555,7 @@
PROJINC=
PROJLIB=
+PROJSHARE=
# With PROJ includes directory
@@ -580,13 +581,11 @@
LOC_CHECK_LIBS(proj,pj_get_def,External PROJ.4,$PROJLIB,PROJLIB,,,)
-# Define share/proj/ directory for epsg code file
-PROJSHARE=
-if test -n "$PROJINC"; then
- PROJSHARE=/usr/share/proj
-else
- PROJSHARE=/usr/local/share/proj
-fi
+# With PROJ share directory
+LOC_CHECK_SHARE_PATH(proj,External PROJ.4,PROJSHARE)
+LOC_CHECK_SHARE(epsg,External PROJ.4,$PROJSHARE)
AC_SUBST(PROJINC)
AC_SUBST(PROJLIB)
Index: aclocal.m4
RCS file: /grassrepository/grass6/aclocal.m4,v
retrieving revision 1.25
diff -u -r1.25 aclocal.m4
--- aclocal.m4 28 Apr 2006 05:40:28 -0000 1.25
+++ aclocal.m4 28 Apr 2006 19:06:04 -0000
@@ -1466,3 +1466,38 @@
dnl XXXXXXXXXXX End Stolen from cdrtools-2.01 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
+dnl macros to find files in ../share/ directories
+AC_DEFUN(LOC_ARG_WITH_SHARE,[
+AC_ARG_WITH($1-share,
+LOC_PAD([ --with-$1-share=DIR])[$2 data files are in DIR])
+dnl check for epsg file and friends in proj
+AC_DEFUN(LOC_CHECK_SHARE_PATH,[
+AC_MSG_CHECKING(for location of $2 data files)
+case "$with_$1_share" in
+y | ye | yes | n | no)
+ AC_MSG_ERROR([*** You must supply a directory to --with-$1-share.])
+esac
+AC_MSG_RESULT($with_$1_share)
+if test -n "$with_$1_share" ; then
+ if test -d "$with_$1_share"; then
+ $3="$$3 -I$dir"
+ else
+ AC_MSG_ERROR([*** $2 data directory $dir does not exist.])
+ fi
+fi
+AC_DEFUN(LOC_CHECK_SHARE,[
+AC_CHECK_FILE($3/$1, [], ifelse($4,[],[
+ AC_MSG_ERROR([*** Unable to locate $2 data files.])
+], $4))
+LOC_CHECK_SHARE(epsg,External PROJ.4,$PROJSHARE,[
+AC_MSG_WARN([*** Unable to locate PROJ data files.])
