[GRASS5] Re: auto-locate EPSG
Sat Apr 29 12:50:35 EDT 2006
Markus Neteler wrote:
> I tried to add you suggestions bug autoconf gives me bad
> news. Apparently I made something wrong.
There were some bugs in the macros in my email.
> Attached a opatch with your suggestions - may I ask you
> to try it (at least autoconf-2.13) and then submit?
> Hamish is elected beta tester for Debian :-)
I've committed the changes. Everything appears to work insofar as the
specified directory gets passed to the projshare.sed script.
