[GRASS-dev] Re: GRASS bugs
Maciej Sieczka
tutey at o2.pl
Wed Aug 2 13:15:56 EDT 2006
Glynn Clements napisa?(a):
> Moritz Lennert wrote:
>>> But generally: why wait for a bugfix party? Just go ahead...
>> I don't think it is about waiting, it is about creating a special,
>> motivating event where everyone works together on one goal.
> The one thing which would do the most to motivate me to fix bugs would
> be a list of clearly-identified, verified, reproducible bugs.
I can do that and will send it to the list. Most likely next week. If
there is no obvious test case I will try to create it based on spearfish.
To all you Guys who were willing to help with testing during the bug
sqaushing party: please give me a hand with that. Each of you, pick few
reports, verify it using spearfish, or, for bugs in the interface etc.,
just verify if it is still present in current CVS. Then 'reply' from the
tracker CCing me at my email. You can do it all even as guest, just make
sure you sign with name and email. If I counted OK there should be 5
testers alltogether. Such a band can clean the mess up easily. Anybody -
please join!
> Back when I used to check the RT occasionally, I would generally skip
> any report where I couldn't quickly reproduce the problem from the
> information contained in the report.
I agree this is often the case that people don't document their reports
well enough, but this doesn't mean such reports should be ignored
completely.
> As this tends to be the case for the vast majority of reports, I
> eventually gave up checking the RT altogether
> (other than to kill requests generated by spam email to the grass-bugs
> address).
Please don't waste your time. This is such an easy task I can do it
myself (and I'm doing it).
> If people want a bug to get fixed, by far the most important factor is
> providing a clear mechanism to demonstrate the bug, either using the
> spearfish dataset or starting from a new location (i.e. using
> self-generated test data).
I know, I've failed to do it often too. But I also reported bugs, and
saw other's reports, documented well but still never taken care of.
You are right there is a need to clean up the tracker further to make
developers' work easier. I'll work on this as I can.
Maciek
