[GRASS-dev] rotated ps.map
Bob Covill bcovill at tekmap.ns.ca
Wed Aug 2 13:21:42 EDT 2006
Hello,
I recently noticed a small bug(?) is ps.map. If the "-r" option is used
to rotate the plot, the output scale is automatically adjusted based on
an un-rotated map. In other words a map scaled to nicely fit on a
rotated page is scaled down based on the dimensions of the page which is
not rotated.
The attached patch for r_paper.c should fix this problem. Please test
and see if this is the best solution (maybe there is an easier fix) to
the problem.
Thanks.
Bob
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060802/7df2f0f0/r_paper.bin
