[GRASS-dev] rotated ps.map
Markus Neteler neteler at itc.it
Fri Aug 4 03:38:53 EDT 2006
On Wed, Aug 02, 2006 at 02:21:42PM -0300, Bob Covill wrote:
> Hello,
> I recently noticed a small bug(?) is ps.map. If the "-r" option is used
> to rotate the plot, the output scale is automatically adjusted based on
> an un-rotated map. In other words a map scaled to nicely fit on a
> rotated page is scaled down based on the dimensions of the page which is
> not rotated.
> The attached patch for r_paper.c should fix this problem. Please test
> and see if this is the best solution (maybe there is an easier fix) to
> the problem.
> Thanks.
Bob,
I have applied your patch (untested) to CVS-HEAD.
Markus
