[GRASS-dev] rotated ps.map
Bob Covill
bcovill at tekmap.ns.ca
Fri Aug 4 07:27:14 EDT 2006
Markus,
Thanks for applying the patch.
Bob
On Fri, 2006-08-04 at 09:38 +0200, Markus Neteler wrote:
> On Wed, Aug 02, 2006 at 02:21:42PM -0300, Bob Covill wrote:
> > Hello,
> > I recently noticed a small bug(?) is ps.map. If the "-r" option is used
> > to rotate the plot, the output scale is automatically adjusted based on
> > an un-rotated map. In other words a map scaled to nicely fit on a
> > rotated page is scaled down based on the dimensions of the page which is
> > not rotated.
> > The attached patch for r_paper.c should fix this problem. Please test
> > and see if this is the best solution (maybe there is an easier fix) to
> > the problem.
> > Thanks.
> Bob,
> I have applied your patch (untested) to CVS-HEAD.
> Markus
