[GRASS-dev] [bug #4915] (grass) gis.m: cannot use v.in.ogr if no monitor is open
Maciek Sieczka via RT grass-bugs at intevation.de
Thu Aug 3 12:04:44 EDT 2006
mlennert at club.worldonline.be wrote (Mon, Jul 31 2006 15:16:34):
> Markus Neteler via RT wrote:
> > For me it works.
> Did you close the map display and launch v.in.ogr from the file menu ?
> Can someone else try ?
I confirm:
1. gis.m
2. close map window
3. run v.in.ogr (on anything, no special test case required):
GRASS_INFO_ERROR(13160,1): region for current mapset is not set
GRASS_INFO_ERROR(13160,1): run "g.region"
The differece in my case is that I don't get the tcltk error as Moritz, only
the error about missing region setting.
What's more however, it seems you can't import ANY data: r.in.* and all the
other v.in.* modules don't work either if Map window is closed and the import
module is started from gis.m.
Maciek
-------------------------------------------- Managed by Request Tracker
