[GRASS-dev] [bug #4960] (grass) gis.m has menu entries for nonexisting modules
Michael Barton michael.barton at asu.edu
Fri Aug 4 18:21:16 EDT 2006
I suppose a partial solution would be to at least check to see if the
command file listed in the menu exists in one of the 3 standard locations
and return something on the order of "This GRASS command is not installed".
It wouldn't help if it was installed but not executable.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Fri, 4 Aug 2006 22:56:35 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: M?ris Nartišs <maris.gis at gmail.com>, <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] [bug #4960] (grass) gis.m has menu entries for
> nonexisting modules
> Michael Barton wrote:
>> Glynn's right. I got ahead of myself in encouraging this fix. Making a
>> better error trapping is a good idea. However this script can't just look in
>> $GISBASE/bin, it also has to look in $GISBASE/scripts and $GISBASE/etc/gm(or
>> dm)/script.
> And, as I already mentioned, a given command may or may not have a
> .exe suffix. E.g. in the MinGW versions which I've built, programs
> only get a .exe suffix if they don't contain any dots. OTOH, it's
> possible to build an executable with no dots and without a .exe
> suffix, and equally possible for an individual Makefile to force a
> .exe suffix on any executable.
> More generally, trying to figure out in advance whether executing a
> given command will succeed is the wrong approach. The only reliable
> approach is to actually run the command and check whether or not it
> did succeed. If it didn't succeed, figuring out why isn't entirely
> straightforward, as the error message (corresponding to ENOENT) will
> vary between platforms, and depend upon the user's locale settings.
