[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Michael Barton michael.barton at asu.edu
Sat Aug 5 11:35:12 EDT 2006
Hola Agustin,
The first 2 errors (I think) are because it somehow can¹t find the icon
images in the icon folder that come with the package. It should find these
if the icon folder is correctly located inside the py_gm folder and you cd
to this folder to run gism.py. Could you check these?
For the second error, I don¹t have PYTHONBIN set on my Mac (at least not
obviously). Nothing is returned with $PYTHONBIN and I don¹t have a
.bash_profile.
That said, I¹m sure that something is set to point toward the Python 2.4
installation. I installed ActiveState¹s Python 2.4 binaries and this
probably does some automatic environment setting. Also, there is Apple¹s
Python 2.3 installed in a slightly different location that may cause
confusion. The message you got is probably a good idea to make sure that the
proper Python installation is being referenced.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Sat, 5 Aug 2006 12:42:33 +0200
To: Michael Barton <michael.barton at asu.edu>
Cc: Grass Developers List <grass-dev at grass.itc.it>
Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
On a Imac running PPC 10.4.7
I got this error when launching
21:12:53: No handler found for image type.
21:12:53: no bitmap handler for type 50 defined.
Other than that it works.
I have a hard time figuring up the correct setting until I got this
"You¹ll want to add the following environment variables. Open or create the
file .bash_profile in your home directory and add the following:
PYTHONBIN=/Library/Frameworks/Python.framework/Versions/2.4/bin
export PATH=/usr/local/bin:/usr/local/sbin:$PYTHONBIN:$PATH
Agustin
Dr. Agustin Diez Castillo
Departament de Prehistoria i Arqueologia
Universitat de Valencia         Phone: +34 963 86 42 42
Avda. Blasco Iba­ez, 28         Fax:   +34 963 98 38 87
Valencia 46010
On 04/08/2006, at 07:55 AM, Michael Barton wrote:
> d.rast elevation_dem, d.vect roads color=red
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060805/ec2711ab/attachment.html
