[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Agustin Diez Castillo
adiez at uv.es
Sat Aug 5 06:42:33 EDT 2006
On a Imac running PPC 10.4.7
I got this error when launching
21:12:53: No handler found for image type.
21:12:53: no bitmap handler for type 50 defined.
Other than that it works.
I have a hard time figuring up the correct setting until I got this
"You’ll want to add the following environment variables. Open or
create the file .bash_profile in your home directory and add the
following:
PYTHONBIN=/Library/Frameworks/Python.framework/Versions/2.4/bin
export PATH=/usr/local/bin:/usr/local/sbin:$PYTHONBIN:$PATH
Agustin
Dr. Agustin Diez Castillo
Departament de Prehistoria i Arqueologia
Universitat de Valencia Phone: +34 963 86 42 42
Avda. Blasco Iba–ez, 28 Fax: +34 963 98 38 87
Valencia 46010
On 04/08/2006, at 07:55 AM, Michael Barton wrote:
> d.rast elevation_dem, d.vect roads color=red
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060805/2a51fe77/attachment.html
