[GRASS-dev] GRASS & cygwin quite slow
Glynn Clements
glynn at gclements.plus.com
Sat Aug 5 13:01:11 EDT 2006
Michael Barton wrote:
> > Executing external programs (e.g. using g.list to generate a list of
> > maps) doesn't work. The actual OpenGL rendering works fine.
> This bombs in the prototype wxPython UI too. Is this somehow different from
> other GRASS modules?
Oops. The NVIZ map browser uses "ls", not g.list.
In any case, it appears to be a Tcl/Tk issue. The code works from a
normal wish shell, so something specific to the NVIZ code interferes
with the exec command.
