[GRASS-dev] Mac OS X frameworks beta 2
Scott Mitchell
smitch at mac.com
Sun Aug 6 10:47:34 EDT 2006
I've been using a new Macbook to test this out - so unfortunately
everything's new, complicating troubleshooting, but I'm catching up.
I downloaded the frameworks, and installed. Tried your GRASS.app,
and it's working well, at least in light testing. Then tried
compiling against your frameworks, and that worked once I got the
hang of the flags. Finding this updated post of yours was a big
help. Did my own compile of 6.1-RC1, and it went cleanly. Starting
up the program, after choosing the mapset, two of the gis.m windows
briefly appear (I think it's the credits screen and the command
history window), then all disappears, and I'm left with only the
GRASS prompt. Finally noticed that this was using the Aqua wish - so
setting env vbls to use X11 wish, and it seems to be working fine.
Will keep playing, just wanted to send some feedback.
Cheers,
Scott
On 29-Jul-06, at 2:11 PM, William Kyngesburye wrote:
> Fine tuned a few things. For all frameworks, they should work in
> Panther now (10.3.9). It was simpler than I made it sound ^_^ I
> also switched to disk images for distribution because I was having
> problems with Apple's zipping.
> The GEOS framework includes both normal C++ and C APIs in one. So,
> saying -framework GEOS is the same as saying -lgeos -lgeos_c, like
> I do with the UnixImageIO framework.
> For the UnixImageIO framework, I linked the unix/lib/*.dylib's to
> the framework itself instead of the internal libraries, so no
> messing around with configure scripts should be needed now. And
> that effectively hides the internal libraries.
> Curl was added internally to the GDAL framework for the Panther
> compatibility.
> I may have broken something else, and there may still be other
> issues to work out, but it's beta.
> To go along with this (sorry for the cross-posting on this),
> another GRASS.app beta. It now should work in Panther (but I
> haven't tested it much there). I made it automatically start X11
> if not running already. Updated to today's CVS snapshot.
> As an example to use the frameworks, here's part of my GRASS
> configure line:
> ./configure --enable-sysv --with-freetype --with-freetype-
> includes="/Library/Frameworks/FreeType.framework/Headers/freetype2 \
> /Library/Frameworks/FreeType.framework/Headers" \
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config \
> --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/
> Headers \
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj \
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/
> Headers \
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/
> Headers \
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/
> Headers \
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-cxx --with-sqlite \
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/Headers \
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/Headers \
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib \
> --with-tcltk-includes=/usr/local/grasslibs/include \
> --with-tcltk-libs=/usr/local/grasslibs/lib \
> --with-x --without-motif --without-glw --with-opengl=x11
> The Tcl/Tk libs are an X11 build. I left out the various DB
> options, you would use those as you normally would.
> Notice how the includes point to the Headers folder in the
> frameworks, and the libs point to the unix/lib in the frameworks.
> Since the actual binary of the library is the framework name, the
> unix/lib has a normal lib*.dylib symlinked to the framework binary,
> so detecting and using -lfoo works.
> If a *-config script is used, like for GDAL, the script will give
> you the correct -framework and include flags to use.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what
> does that remind me of? Ah, yes - life."
> - Marvin
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
