[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Michael Barton michael.barton at asu.edu
Mon Aug 7 13:22:46 EDT 2006
Moritz and Yann,
I forgot to ask you. Are you using whatever came with Debian unstable, or
did you install the latest and greatest Python 2.4.2.xx (I'm on 2.4.3.11)
and wxPython 2.6.3.x?
Image dragging works very smoothly on my Mac. How does resizing look? A
buffered DC can be used to reduce flicker, but is a bit of a pain to
implement. Need to know if it is needed on some systems or the problem is an
issue of different versions of the software.
Check out the new version I just uploaded.
Cheers
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Fri, 04 Aug 2006 10:28:47 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Grass Developers List <grass-dev at grass.itc.it>, Jachym Cepicky
> <jachym.cepicky at centrum.cz>, Trevor Wiens <twiens at interbaun.com>, David
> Finlayson <david.p.finlayson at gmail.com>
> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
> Panning however causes problems for me:
> - first the screen flashes very frequently while the map moves
> - once the map is in its new position, I cannot use the mouse anymore,
> only my keyboard. However, when I change to another workspace of my
> Gnome desktop and then switch back again, the map display is empty, but
> I can use my mouse again.
