[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Moritz Lennert
mlennert at club.worldonline.be
Tue Aug 8 03:34:32 EDT 2006
Michael Barton wrote:
> Moritz and Yann,
> I forgot to ask you. Are you using whatever came with Debian unstable, or
> did you install the latest and greatest Python 2.4.2.xx (I'm on 2.4.3.11)
> and wxPython 2.6.3.x?
I have tried it with
python 2.4.3-7
and wxptyhon 2.6.1.2 (from Ubuntu as the debian version is still
compiled against python2.3)
and I still have the same problem with panning.
To test with newer version I will have to compile myself. I'll do that
when I find the time.
> Image dragging works very smoothly on my Mac. How does resizing look?
I assume you mean window resizing. It doesn't work: I can see the map
flicker at the correct, resized size, but then the display is grey. When
I click on the "display map" button, it appears at the original size,
thus only filling a part of the screen.
> A
> buffered DC can be used to reduce flicker, but is a bit of a pain to
> implement. Need to know if it is needed on some systems or the problem is an
> issue of different versions of the software.
> Check out the new version I just uploaded.
> Cheers
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Moritz Lennert <mlennert at club.worldonline.be>
>> Date: Fri, 04 Aug 2006 10:28:47 +0200
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: Grass Developers List <grass-dev at grass.itc.it>, Jachym Cepicky
>> <jachym.cepicky at centrum.cz>, Trevor Wiens <twiens at interbaun.com>, David
>> Finlayson <david.p.finlayson at gmail.com>
>> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
>> Panning however causes problems for me:
>> - first the screen flashes very frequently while the map moves
>> - once the map is in its new position, I cannot use the mouse anymore,
>> only my keyboard. However, when I change to another workspace of my
>> Gnome desktop and then switch back again, the map display is empty, but
>> I can use my mouse again.
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
