[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Yann Chemin
ychemin at gmail.com
Tue Aug 8 03:48:04 EDT 2006
Using the pan mode works with 1 second delay, but then i cannot exit
from it, the button is always selected (does not give back control to
other buttons), have to kill it (Alt+F4).
using "zoom in" produces a blank map. Using "Zoom out" works well.
On 08/08/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> Michael Barton wrote:
> > Moritz and Yann,
> > I forgot to ask you. Are you using whatever came with Debian unstable, or
> > did you install the latest and greatest Python 2.4.2.xx (I'm on 2.4.3.11)
> > and wxPython 2.6.3.x?
> I have tried it with
> python 2.4.3-7
> and wxptyhon 2.6.1.2 (from Ubuntu as the debian version is still
> compiled against python2.3)
> and I still have the same problem with panning.
> To test with newer version I will have to compile myself. I'll do that
> when I find the time.
> > Image dragging works very smoothly on my Mac. How does resizing look?
> I assume you mean window resizing. It doesn't work: I can see the map
> flicker at the correct, resized size, but then the display is grey. When
> I click on the "display map" button, it appears at the original size,
> thus only filling a part of the screen.
> > A
> > buffered DC can be used to reduce flicker, but is a bit of a pain to
> > implement. Need to know if it is needed on some systems or the problem is an
> > issue of different versions of the software.
> > Check out the new version I just uploaded.
> > Cheers
> > Michael
> > __________________________________________
> > Michael Barton, Professor of Anthropology
> > School of Human Evolution & Social Change
> > Center for Social Dynamics and Complexity
> > Arizona State University
> > phone: 480-965-6213
> > fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> >> From: Moritz Lennert <mlennert at club.worldonline.be>
> >> Date: Fri, 04 Aug 2006 10:28:47 +0200
> >> To: Michael Barton <michael.barton at asu.edu>
> >> Cc: Grass Developers List <grass-dev at grass.itc.it>, Jachym Cepicky
> >> <jachym.cepicky at centrum.cz>, Trevor Wiens <twiens at interbaun.com>, David
> >> Finlayson <david.p.finlayson at gmail.com>
> >> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
> >> Panning however causes problems for me:
> >> - first the screen flashes very frequently while the map moves
> >> - once the map is in its new position, I cannot use the mouse anymore,
> >> only my keyboard. However, when I change to another workspace of my
> >> Gnome desktop and then switch back again, the map display is empty, but
> >> I can use my mouse again.
> > grass-dev mailing list
> > http://grass.itc.it/mailman/listinfo/grass-dev
