[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Michael Barton michael.barton at asu.edu
Tue Aug 8 11:11:34 EDT 2006
Moritz and Yann,
I hope to be able to test this on FC4 and Debian soon here. I'll let you
know if we have the same issues.
My guess is that if it's a version issue, it's with wxPython, since we're
all using Python 2.4.3.
You might check the change log of 2.6.1 to 2.6.3 changes.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Tue, 08 Aug 2006 09:34:32 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Yann Chemin <ychemin at gmail.com>, Trevor Wiens <twiens at interbaun.com>,
> David Finlayson <david.p.finlayson at gmail.com>, Jachym Cepicky
> <jachym.cepicky at centrum.cz>, Grass Developers List <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
> Michael Barton wrote:
>> Moritz and Yann,
>> I forgot to ask you. Are you using whatever came with Debian unstable, or
>> did you install the latest and greatest Python 2.4.2.xx (I'm on 2.4.3.11)
>> and wxPython 2.6.3.x?
> I have tried it with
> python 2.4.3-7
> and wxptyhon 2.6.1.2 (from Ubuntu as the debian version is still
> compiled against python2.3)
> and I still have the same problem with panning.
> To test with newer version I will have to compile myself. I'll do that
> when I find the time.
>> Image dragging works very smoothly on my Mac. How does resizing look?
> I assume you mean window resizing. It doesn't work: I can see the map
> flicker at the correct, resized size, but then the display is grey. When
> I click on the "display map" button, it appears at the original size,
> thus only filling a part of the screen.
>> A
>> buffered DC can be used to reduce flicker, but is a bit of a pain to
>> implement. Need to know if it is needed on some systems or the problem is an
>> issue of different versions of the software.
>> Check out the new version I just uploaded.
>> Cheers
>> Michael
>> Center for Social Dynamics and Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Fri, 04 Aug 2006 10:28:47 +0200
>>> Cc: Grass Developers List <grass-dev at grass.itc.it>, Jachym Cepicky
>>> <jachym.cepicky at centrum.cz>, Trevor Wiens <twiens at interbaun.com>, David
>>> Panning however causes problems for me:
>>> - first the screen flashes very frequently while the map moves
>>> - once the map is in its new position, I cannot use the mouse anymore,
>>> only my keyboard. However, when I change to another workspace of my
>>> Gnome desktop and then switch back again, the map display is empty, but
>>> I can use my mouse again.
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
