[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Yann Chemin
ychemin at gmail.com
Tue Aug 8 11:32:25 EDT 2006
Hi Michael,
here is the gism.py with image module completed.
Yann
On 08/08/06, Michael Barton <michael.barton at asu.edu> wrote:
> Moritz and Yann,
> I hope to be able to test this on FC4 and Debian soon here. I'll let you
> know if we have the same issues.
> My guess is that if it's a version issue, it's with wxPython, since we're
> all using Python 2.4.3.
> You might check the change log of 2.6.1 to 2.6.3 changes.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Moritz Lennert <mlennert at club.worldonline.be>
> > Date: Tue, 08 Aug 2006 09:34:32 +0200
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: Yann Chemin <ychemin at gmail.com>, Trevor Wiens <twiens at interbaun.com>,
> > David Finlayson <david.p.finlayson at gmail.com>, Jachym Cepicky
> > <jachym.cepicky at centrum.cz>, Grass Developers List <grass-dev at grass.itc.it>
> > Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
> > Michael Barton wrote:
> >> Moritz and Yann,
> >> I forgot to ask you. Are you using whatever came with Debian unstable, or
> >> did you install the latest and greatest Python 2.4.2.xx (I'm on 2.4.3.11)
> >> and wxPython 2.6.3.x?
> > I have tried it with
> > python 2.4.3-7
> > and wxptyhon 2.6.1.2 (from Ubuntu as the debian version is still
> > compiled against python2.3)
> > and I still have the same problem with panning.
> > To test with newer version I will have to compile myself. I'll do that
> > when I find the time.
> >> Image dragging works very smoothly on my Mac. How does resizing look?
> > I assume you mean window resizing. It doesn't work: I can see the map
> > flicker at the correct, resized size, but then the display is grey. When
> > I click on the "display map" button, it appears at the original size,
> > thus only filling a part of the screen.
> >> A
> >> buffered DC can be used to reduce flicker, but is a bit of a pain to
> >> implement. Need to know if it is needed on some systems or the problem is an
> >> issue of different versions of the software.
> >> Check out the new version I just uploaded.
> >> Cheers
> >> Michael
> >> Center for Social Dynamics and Complexity
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >>> Date: Fri, 04 Aug 2006 10:28:47 +0200
> >>> Cc: Grass Developers List <grass-dev at grass.itc.it>, Jachym Cepicky
> >>> <jachym.cepicky at centrum.cz>, Trevor Wiens <twiens at interbaun.com>, David
> >>> Panning however causes problems for me:
> >>> - first the screen flashes very frequently while the map moves
> >>> - once the map is in its new position, I cannot use the mouse anymore,
> >>> only my keyboard. However, when I change to another workspace of my
> >>> Gnome desktop and then switch back again, the map display is empty, but
> >>> I can use my mouse again.
> >> _______________________________________________
> >> grass-dev mailing list
> >> http://grass.itc.it/mailman/listinfo/grass-dev
Type: text/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060808/6ad9a149/gism.py
