[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Michael Barton michael.barton at asu.edu
Mon Aug 7 13:37:47 EDT 2006
> Sorry it was a typo indeed,
> grass-interface.dtd and grassgui.py are the two files to be copied
> over to py_gm/
Yes. I quickly found you you need grassgui.py and grassgui.dtd. Is the
latter an xml schema???
> Would it be possible to drop py_gm/ into grass6/gui/wxpython/ ? since
> they both can interoperate, it should facilitate the temptation of a
> python programmer to "plug" them together through the py_gm/
> buttons...
See my post from today. I agree with putting this in that local. If there is
general agreement, I can do so. But also see the problem I had with running
it from something like $GISBASE/etc/wxp. Maybe you know what I am doing
wrong there.
I just did plug them together. Works pretty slick.
> Another thought, would it be interesting to develop a program to
> convert the .tcl code into python interface? or is it better to recode
> directly in Python?
For me at least, it is easier to just recode. But maybe someone out there is
clever enough to do this. It would be a big time saver.
Michael
> Yann
> On 05/08/06, Agustin Diez Castillo <adiez at uv.es> wrote:
>> Do you mean grass-interface.dtd? I have no grass-interface.py
>> grass6/gui/wxpython/grass-interface.py into py_gm/ from which you run
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
