[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Michael Barton
michael.barton at asu.edu
Sat Aug 5 11:35:52 EDT 2006
This is great. I'll have to try it out and see what happens.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Yann Chemin <ychemin at gmail.com>
> Date: Sat, 5 Aug 2006 14:12:05 +0700
> To: Grass Developers List <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
>>> First step could be, implement Jan-Oliver's grassgui.py script
>>> (grass6/gui/wxpython) :-) should be pretty easy.
> Well, it actually works already.. somehow.
> 1-copy grass6/gui/wxpython/grassgui.py and
> grass6/gui/wxpython/grass-interface.py into py_gm/ from which you run
> the "python gism.py &" command.
> 2-open GRASScvs and select i.e. Spearfish
> 3-cd /dir/to/py_gm/ ; python gism.py &
> 4-Once the gism.py opens the GRASS GIS GUI, type the following in the
> command line interface of the GUI: "d.rast --interface-description |
> python grassgui.py"
> 5-d.rast GUI will appear, type i.e. elevation.10m, then select OK
> button and close the d.rast GUI (Upper Right X Button for example).
> After destroying the d.rast GUI, elevation.10m will be displayed in
> the Map Display-1.
> anybody who knows a little bit of Python might indicate how we could
> get this seemlessly into the actual GUI.
> Yann
> On 05/08/06, Michael Barton <michael.barton at asu.edu> wrote:
>> A VERY good idea.
>> Michael
>> Center for Social Dynamics and Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: Jachym Cepicky <jachym.cepicky at centrum.cz>
>>> Date: Fri, 4 Aug 2006 10:29:48 +0200
>>> To: Michael Barton <michael.barton at asu.edu>
>>> Cc: Grass Developers List <grass-dev at grass.itc.it>, Trevor Wiens
>>> <twiens at interbaun.com>, David Finlayson <david.p.finlayson at gmail.com>
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
