[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Yann Chemin
ychemin at gmail.com
Mon Aug 7 21:28:30 EDT 2006
Hello Glynn,
Sorry to ask this new bie question, but you mean that the front-end
should be a file called from the GUI and this front-end will somehow
launch r.mapcalc, don't you?
thanks,
Yann
On 08/08/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Yann Chemin wrote:
> > > r.mapcalc doesn't use G_parser(); anything other than "help" or
> > > "--help" will be parsed as an expression.
> > by removing "--interface-description | python grassguy.py" and just
> > calling r.mapcalc, then the terminal from which we launched "python
> > gism.py" gets the r.mapcalc session opened.
> > There must be a way to (at least) make it run from the GUI integrated CLI.
> Write a front-end script, e.g.:
> #!/bin/bash
> #%Module
> #% description: r.mapcalc - Raster map layer data calculator
> #%End
> #%option
> #% key: expression
> #% type: string
> #% description: mapcalc expression
> #% required : yes
> #%end
> if [ "$1" != "@ARGS_PARSED@" ]
> then
> exec g.parser "$0" "$@"
> fi
> exec r.mapcalc "$GIS_OPT_EXPRESSION"
> Changing r.mapcalc itself to use G_parser() isn't practical.
