[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Michael Barton
michael.barton at asu.edu
Tue Aug 8 12:45:55 EDT 2006
Well, that seems to be what is going on. I guess we need to require wxPython
2.6.3.
Also, for the moment, I've put a py_gm folder and individual files on my
website so that I don't have to repackage everything when a new update comes
in.
I've put in your very nice menu updates. I put Glynn's script into a scripts
folder inside py_gm and changed the reference in the menu accordingly. There
are several other scripts I'm putting in there as well. These are commands
that won't run correctly using their normal interface descriptions (e.g.,
r.reclass with the rules flag checked). I made them so that they have a
proper interface in the GIS Manager. They will work just the same with the
wxPython version.
Thanks again for your help.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Yann Chemin <ychemin at gmail.com>
> Date: Tue, 8 Aug 2006 23:28:37 +0700
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Moritz Lennert <mlennert at club.worldonline.be>, Trevor Wiens
> <twiens at interbaun.com>, David Finlayson <david.p.finlayson at gmail.com>, Jachym
> Cepicky <jachym.cepicky at centrum.cz>, Grass Developers List
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
> It seems that it has been discussed on this www:
> http://blog.gmane.org/gmane.comp.python.wxpython.devel/month=20060101
> On 08/08/06, Michael Barton <michael.barton at asu.edu> wrote:
>> These changes, especially the scaled bitmap (which I use for window
>> resizing) would significantly affect how the app works.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Tue, 8 Aug 2006 23:07:06 +0700
>>> Jachym
>>> the version installed here is wxPythonGTK2.6-2.6.3.3-2mdv2007.0
>>> from wxpython www:
>>> last changes from 2.6.2.1 are dealing with :
>>> Added wx.SizerItem.SetUserData
>>> A variety of updates to wx.lib.floatcanvas, including Added
>>> DrawObjects, including a ScaledTextBox, with auto-wrapping, etc, and
>>> Scaled and Unscaled Bitmap Objects.
>>> WARNING: Changed all DrawObjects to take an (x,y) pair rather than
>>> individual x,y parameters. Also changed rectangles and ellipses to
>>> take (w,h) pair. This is an API change, but should be easy to
>>> accommodate, all you need to do is add a parenthesis pair: (...x, y,
>>> ...) ---> (...(x,y), ...)
>>> maybe somebody can understand more than i can... :-)
>>>> Moritz and Yann,
>>>> I hope to be able to test this on FC4 and Debian soon here. I'll let you
>>>> know if we have the same issues.
>>>> My guess is that if it's a version issue, it's with wxPython, since we're
>>>> all using Python 2.4.3.
>>>> You might check the change log of 2.6.1 to 2.6.3 changes.
>>>> Michael
>>>> Center for Social Dynamics & Complexity
>>>> phone: 480-965-6213
>>>> fax: 480-965-7671
>>>>> From: Moritz Lennert <mlennert at club.worldonline.be>
>>>>> Date: Tue, 08 Aug 2006 09:34:32 +0200
>>>>> Cc: Yann Chemin <ychemin at gmail.com>, Trevor Wiens <twiens at interbaun.com>,
>>>>> David Finlayson <david.p.finlayson at gmail.com>, Jachym Cepicky
>>>>> Michael Barton wrote:
>>>>>> Moritz and Yann,
>>>>>> I forgot to ask you. Are you using whatever came with Debian unstable, or
>>>>>> did you install the latest and greatest Python 2.4.2.xx (I'm on 2.4.3.11)
>>>>>> and wxPython 2.6.3.x?
>>>>> I have tried it with
>>>>> python 2.4.3-7
>>>>> and wxptyhon 2.6.1.2 (from Ubuntu as the debian version is still
>>>>> compiled against python2.3)
>>>>> and I still have the same problem with panning.
>>>>> To test with newer version I will have to compile myself. I'll do that
>>>>> when I find the time.
>>>>>> Image dragging works very smoothly on my Mac. How does resizing look?
>>>>> I assume you mean window resizing. It doesn't work: I can see the map
>>>>> flicker at the correct, resized size, but then the display is grey. When
>>>>> I click on the "display map" button, it appears at the original size,
>>>>> thus only filling a part of the screen.
>>>>>> A
>>>>>> buffered DC can be used to reduce flicker, but is a bit of a pain to
>>>>>> implement. Need to know if it is needed on some systems or the problem is
>>>>>> an
>>>>>> issue of different versions of the software.
>>>>>> Check out the new version I just uploaded.
>>>>>> Cheers
>>>>>> Michael
>>>>>> phone: 480-965-6213
>>>>>> fax: 480-965-7671
>>>>>>> Date: Fri, 04 Aug 2006 10:28:47 +0200
>>>>>>> Cc: Grass Developers List <grass-dev at grass.itc.it>, Jachym Cepicky
>>>>>>> <jachym.cepicky at centrum.cz>, Trevor Wiens <twiens at interbaun.com>, David
>>>>>>> Panning however causes problems for me:
>>>>>>> - first the screen flashes very frequently while the map moves
>>>>>>> - once the map is in its new position, I cannot use the mouse anymore,
>>>>>>> only my keyboard. However, when I change to another workspace of my
>>>>>>> Gnome desktop and then switch back again, the map display is empty, but
>>>>>>> I can use my mouse again.
>>>>>> _______________________________________________
>>>>>> grass-dev mailing list
>>>>>> http://grass.itc.it/mailman/listinfo/grass-dev
