[GRASS-dev] Re: New installation for wxPython GUI
Michael Barton
michael.barton at asu.edu
Wed Aug 9 14:56:55 EDT 2006
Yann,
See below.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Yann Chemin <ychemin at gmail.com>
> Date: Wed, 9 Aug 2006 10:14:37 +0700
> To: Michael Barton <michael.barton at asu.edu>, Grass Developers List
> <grass-dev at grass.itc.it>
> Subject: Re: New installation for wxPython GUI
> Works nicely on my system!
> About "Zoom in" behaviour, i can replicate the reason why it displays
> a blank screen.
> 1-type d.rast elevation.dem
> 2-click in any point of the elevation map
> 3-becomes blank screen
It is blank because you've zoomed in too far...because the single-click
zooming is not yet implemented (and has unpredictable behavior).
> Now, here is the catch, if instead you try;
> 2-POINT and DRAG to create a (invisible on my computer) box in any
> AREA of the elevation map
> 3-map zooms in properly
Box zooming IS implemented and works pretty good (except for being ugly).
> So it must be that "zom in" functionality should be allowed to zoom in
> by factor X (2?) if only a click in a point is made, or something like
> that...
Yes. This needs to be written.
Michael
> y
> On 09/08/06, Michael Barton <michael.barton at asu.edu> wrote:
>> I figured out how to run gism.py from outside the directory where it lives.
>> So now we can run it from a script on the GRASS command line without
>> changing directories.
>> There is a new distribution on my website (both tarzipped package and
>> non-compressed files).
>> For now, just drop the gmwxp folder into your $GISBASE/etc folder and the
>> script "gm.wxp" into the $GISBASE/scripts folder.
>> Then you can just type gm.wxp& from the GRASS command line to start the new
>> GUI. It also reads the existing icon files, so you don't need the separate
>> icon directory anymore.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
