[GRASS-dev] Spearfish user1 database
Radim Blazek radim.blazek at gmail.com
Thu Aug 10 06:52:36 EDT 2006
Hi.
mapset user1 in spearfish_grass60data-0.2.tar.gz
has defined database in VAR file:
  DB_DRIVER: dbf
  DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
but dbf directory (database) does not exists. You should either
remove user1/VAR file or create user1/dbf directory.
Radim
