[GRASS-dev] Spearfish user1 database
Markus Neteler
neteler at itc.it
Thu Aug 10 08:56:04 EDT 2006
Radim Blazek wrote on 08/10/2006 12:52 PM:
> Hi.
> mapset user1 in spearfish_grass60data-0.2.tar.gz
> has defined database in VAR file:
> DB_DRIVER: dbf
> DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> but dbf directory (database) does not exists. You should either
> remove user1/VAR file or create user1/dbf directory.
hi Radim,
where is this a problem (QGIS?)? The user1/dbf directory should be
autocreated
once needed. But yes, we should add it to spearfish_grass60data-0.2.tar.gz.
Markus
