[GRASS-dev] Spearfish user1 database
Radim Blazek
radim.blazek at gmail.com
Thu Aug 10 09:23:07 EDT 2006
The database is only created if database/driver is not set in VAR.
If user sets a database manualy (as he does in user1 mapset)
it is his responsibility to create also the database.
Radim
On 8/10/06, Markus Neteler <neteler at itc.it> wrote:
> Radim Blazek wrote on 08/10/2006 12:52 PM:
> > Hi.
> > mapset user1 in spearfish_grass60data-0.2.tar.gz
> > has defined database in VAR file:
> > DB_DRIVER: dbf
> > DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> > but dbf directory (database) does not exists. You should either
> > remove user1/VAR file or create user1/dbf directory.
> hi Radim,
> where is this a problem (QGIS?)? The user1/dbf directory should be
> autocreated
> once needed. But yes, we should add it to spearfish_grass60data-0.2.tar.gz.
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
