[GRASS-dev] New installation for wxPython GUI
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 10 11:36:56 EDT 2006
Moritz Lennert wrote:
>>>> - the display does not automatically redraw when I drag another window
>>>> over it. I have to click the display map button.
I found a solution to this: change line 49 in mapdisp.py from
self.Bind(wx.EVT_PAINT, self.ReDraw, self.mapPanel)
to
self.Bind(wx.EVT_PAINT, self.ReDraw)
Now whenever the display was hidden and is made visible again, the image
gets redrawn.
It still is a different behaviour from what I see "normally" since there
is a short delay (~1sec) before the display is refreshed. Normally (with
any other window, including the tcltk GIS manager) I don't see any
refresh happening. It is as if the image never was erased. So I guess
there must be another solution.
One option (in case you haven't already seen this, Michael) might be this:
http://wiki.wxpython.org/index.cgi/DoubleBufferedDrawing
for which a class is proposed here:
http://wiki.wxpython.org/index.cgi/BufferedCanvas
A completely different question: Michael, are you planning on continuing
with the raster drawing system via the ppm files, or should the wxpython
manager actually display vector drawings when displaying vector maps ?
Moritz
