[GRASS-dev] grass and python
Michael Barton
michael.barton at asu.edu
Sat Aug 12 15:18:22 EDT 2006
William,
I hope to get the wxPython stuff into the cvs early next week. This will
make it easier for you and others to work with it.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: William Kyngesburye <woklist at kyngchaos.com>
> Reply-To: William Kyngesburye <kyngchaos at kyngchaos.com>
> Date: Sat, 12 Aug 2006 14:07:28 -0500
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] grass and python
> On Aug 12, 2006, at 12:45 PM, Michael Barton wrote:
>> In order to support multiple sessions, I think you simply need to
>> start
>> multiple shells (i.e., command parser with environment settings)
>> for GRASS
>> commands to run in. Lorenzo's binaries will do that now. The biggest
>> convenience for me of multiple GRASS sessions is being able to work in
>> multiple locations simultaneously (though only for brief times or I
>> get
>> confused).
> I sometimes also run multiple GRASS sessions (easy - new Terminal
> window) - handy if I run something in one mapset that takes a LONG
> time, I can putter around with stuff in another mapset. I think
> Lorenzo's handling multiple sessions is because his OSX app actually
> does manage multiple sessions (I don't know), much like I'm thinking
> about how a wxpython might manage multiple sessions, or workspaces,
> the 'document' analogy. Or maybe it just quits after starting GRASS.
> My OnMyCommand startup just passes the startup on to the Terminal and
> the grass init.sh, but OMC app happens to continue running (doing
> nothing) while the GRASS shell continues to run. Thus, the OMC app
> can't run again to start another GRASS session.
> The Python py2app startup (independent of the wxpython GUI) I came up
> with can run multiple sessions, since the python startup app starts
> the GRASS shell in the Terminal, then quits, leaving GRASS running
> and leaving the user the possibility of running the python startup
> again.
> My OMC and python startups don't manage GRASS sessions.
> hmmm, at least I should try to get the OMC startup to not wait around
> for GRASS to quit for now.
>> I've only messed with the app building a couple of times--and
>> didn't get it
>> right yet.
> GRASS.app building, or Mac OS X app building in general? Xcode and
> Mac app development is much too hardcore for me. I'm better off with
> casual programming and scripting and tinkering.
> I have a working Python app startup as an alternative to the OMC
> method I currently use in my app binary. I want something buildable
> and distibutable as source that can either be easily used by anyone
> to build a GRASS.app from source or possibly even included in the
> GRASS source as an option. Then others could more easily play around
> with Mac app builds and customize them.
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
