[GRASS-dev] [bug #5005] (grass) r.shaded.relief syntax error
Request Tracker grass-bugs at intevation.de
Tue Aug 15 05:18:09 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5005
Subject: r.shaded.relief syntax error
Platform: GNU/Linux/x86_64
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: grass-6.3.cvs_src_snapshot_2006_08_12
Compiled as follows:
tar xzvf grass-6.3.cvs_src_snapshot_2006_08_12.tar.gz
cd grass-6.3.cvs_src_snapshot_2006_08_12
CFLAGS="-g -Wall"
./configure \
 --enable-64bit \
 --with-libs=/usr/lib64 \
 --with-postgres \
 --without-fftw \
 --with-postgres-includes=/usr/local/pgsql/include \
 --with-postgres-libs=/usr/local/pgsql/lib
make, make install etc.
when executing:
r.shaded.relief map=infile shadedmap=outfile azimuth=315 altitude=45 units=meters
I get the following message:
Calculating shading, please stand by.
syntax error, unexpected ',', expecting ')'
Parse error
The same command executed in GRASS 6.0.2 works OK.
-------------------------------------------- Managed by Request Tracker
