[GRASS-dev] [bug #5005] (grass) r.shaded.relief syntax error
Markus Neteler
neteler at itc.it
Tue Aug 15 08:56:10 EDT 2006
On Tue, Aug 15, 2006 at 11:18:09AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5005
> Subject: r.shaded.relief syntax error
> Platform: GNU/Linux/x86_64
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.3.cvs_src_snapshot_2006_08_12
> Compiled as follows:
> tar xzvf grass-6.3.cvs_src_snapshot_2006_08_12.tar.gz
> cd grass-6.3.cvs_src_snapshot_2006_08_12
> CFLAGS="-g -Wall"
> ./configure \
> --enable-64bit \
> --with-libs=/usr/lib64 \
> --with-postgres \
> --without-fftw \
> --with-postgres-includes=/usr/local/pgsql/include \
> --with-postgres-libs=/usr/local/pgsql/lib
> make, make install etc.
> when executing:
> r.shaded.relief map=infile shadedmap=outfile azimuth=315 altitude=45 units=meters
> I get the following message:
> Calculating shading, please stand by.
> syntax error, unexpected ',', expecting ')'
> Parse error
> The same command executed in GRASS 6.0.2 works OK.
I can confirm the problem. Fix: Add in the first part of the script:
# setting environment, so that awk works properly in all languages
unset LC_ALL
export LC_NUMERIC=C
It's a LOCALE problem which changes '.' to ',' in certain locales.
Somehow we forgot to add above to this scripts (in other scripts
this fix was done time ago).
Fixed in CVS for 6.3 and 6.2-release branch.
Markus
