[GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
Markus Neteler
neteler at itc.it
Tue Aug 15 15:51:56 EDT 2006
Hi Isaac,
a solution for this (known) problem was proposed by Martin Landa a
few days ago:
http://grass.itc.it/pipermail/grass-dev/2006-August/025040.html
Since he should have CVS write access now, I hope that
he'll submit the patch asap.
Markus
On Tue, Aug 15, 2006 at 06:07:09PM +0000, Isaac Ullah wrote:
> Hi all,
> A very interesting and frustrating problem has just presented
> itself to me. The region settings seem to "break" after using the new
> zoom tools from the map display. i get the following error message in
> the Output window:
> region for current mapset is invalid
> line 15: <depths: 0>
> run "g.region"
> This message displays after zooming a few times, or after attempting
> to do anything at all with "g.region" (including just printing region
> settings). Also, all the new zoom tools in the map display seem to do
> nothing after this message, and I cannot display any of the maps in my
> mapset. I have looked at the WIND file for the afflicted mapsets, and
> they seem perfectly normal. For example, the above error message is
> associated with the following WIND file:
> proj: 1
> zone: 36
> north: 3742844.70455
> south: 3309044.70455
> east: 944264.754065
> west: 560076.932184
> cols: 12806
> rows: 14460
> e-w resol: 30.0006108
> n-s resol: 30
> top: 1
> bottom: 0
> cols3: 12806
> rows3: 14460
> depths: 1
> e-w resol3: 30.0006108
> n-s resol3: 30
> t-b resol: 1
> Making a new mapset allows me to run "g.region" without any problems
> until I use the new zooming tools, and then the same problem occurs.
> Restarting GRASS initially allows for the maps to be displayed again,
> but after zooming a bit, or trying to run "g.region" again, the region
> eventually "breaks" again. What I specifically do not understand is why
> the error tells me to run "g.region" when doing so does nothing, and
> seems to even cause the error in the first place. Does anybody have any
> idea what the issue is here? I am using GRASS 6.3, compiled from the CVS
> source yesterday (08/15)... Any help would be greatly appreciated.
> Cheers,
> Isaac
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
