[GRASS-dev] batch-grass.sh not working with GRASS > 6.0
Robert Nuske
rnuske at gwdg.de
Fri Aug 18 06:29:42 EDT 2006
Dear Developers,
does anybody know why batch-grass.sh
from the GRASS FAQ "How to use GRASS in batch mode?"
does not work anymore?
I run the batch-grass.sh script for the last time successfully in May with
whatever cvs version was up-to-date at that time, probably 6.1.
After fiddling with my grass-scripts and cluelessly looking through
batch-grass.sh I tested all 6.x versions and found that my set-up works with
the 6.0 version but not with the newer versions.
Thats why I am wondering what changed in GRASS to that effect. And what do I
need to do, to get batch-grass.sh working again.
I very much appreciate any hints, tips and fixes.
cheers,
robert
--tests-----------------------------------------------------------
simple test with one command:
./batch-grass.sh eifel nwz2 g.region -p
6.0.2 is okay
grass-6.1.0 - 6.3.cvs give the following
./batch-grass.sh: line 62: 16750 Speicherzugriffsfehler $*
providing the grass commands in a file:
./batch-grass.sh eifel nwz2 -file g_commands.sh
grass-6.0.2 again works
and the others fail with this message:
sh: line 1: 17129 Speicherzugriffsfehler g.region -p
with:
grass-6.3.cvs (cvs from 2006-08-17)
grass-6.2.cvs (built from grass-6.2.cvs_src_snapshot_2006_08_12)
grass-6.1.0 (built from grass-6.1.0.tar.gz)
grass-6.0.2 (built from grass-6.0.2.tar.gz)
