[GRASS-dev] Re: gis.m: resolution not preserved
Michael Barton
michael.barton at asu.edu
Fri Aug 18 16:07:40 EDT 2006
Maciej,
See below. I hope you realize that I and others appreciate the work you do
to find and get fixed all the little (and some not so little) things that
can frustrate GRASS users.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Fri, 18 Aug 2006 21:55:49 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass-dev <grass-dev at grass.itc.it>, Jarek Jasiewicz <jarekj at amu.edu.pl>
> Subject: Re: gis.m: resolution not preserved
> Michael Barton napisa?(a):
>> I think that it's going from res=8 to res=30
> No. It's going from 30 to 8.
> Another example:
> #0 grass63 -text, spearfish60, g.region rast=slope -a, gis.m
> ALL COMMANDS BELOW ARE CALLED FROM gis.m:
> #1 g.region -g
> n=4928030
> s=4913690
> w=589980
> e=609000
> nsres=30
> ewres=30
> rows=478
> cols=634
> #2 add 'slope' raster, display, zoom in (CONSTRAIN mode)
> #3 g.region -g
> n=4925144.14938
> s=4922139.29461
> w=595930.207469
> e=599887.095436
> nsres=30.0485477
> ewres=29.97642399
> rows=100
> cols=132
> #4 swith to EXPLORE mode
> #5 g.region -g
> n=4925144.14938
> s=4922139.29461
> w=595907.492984
> e=599909.809921
> nsres=6.23413853
> ewres=6.23413853
> rows=482
> cols=642
The resolution is a function of the extents. If you zoom in from here, the
res value gets smaller; if you zoom out it gets bigger. It is not related to
prior resolution. It is set so that you get a +/- constant number of pixels
in the display output. This is why it is faster overall.
> As you see, the resolution goes from ~30 to ~6. This will not speed up
> the display, will it?
>> I've done this, going back and forth between modes and can only
>> get it to change resolution if I'm in explore mode. I'll keep
>> looking into it.
> Above you can also see that resolution changed a bit between #1 and #2.
> This proves that gis.m doesn't allign region to resolution, while it
> should (like d.zoom did) to avoid weird results in the output of
> commands that use current region settings.
This is the -a issue, rather than a big change in resolution. I see now.
There is some complication as to where to put the -a so that it doesn't mess
things up when you DON'T want to align to region. I'll try again to put it
in somewhere.
Michael
> I must be really going now. See you next week!
> Cheers,
> Maciek
