[GRASS-dev] Keywords in module descriptions
Michael Barton
michael.barton at asu.edu
Fri Aug 18 13:02:37 EDT 2006
Markus,
I think this is an excellent idea. If we get these keywords arranged right
(it will probably take some experimentation, but you might start with the
current menu hierarchy), it will not only help documentation but could serve
as the basis for an autogenerated menu/toolbox.
Michale
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Markus Neteler <neteler at itc.it>
> Date: Thu, 17 Aug 2006 21:49:32 +0200
> To: GRASS developers list <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] Keywords in module descriptions
> Hi,
> a proposal for a better navigatable documentation of GRASS:
> I would like to add
> module->keywords = _("a, b, c, d");
> to each command. These keywords would then
> - automatically appear in each HTML/MAN page
> - be content of the XML output by --interface-description
> (maybe parsable then <keywords>a, b, c, d</keywords> for
> automated GUI arranging?)
> - probably made visible in the TclTk GUI if we want that
> - visible in the "help" text, example:
> r.cost help
> Description:
> Outputs a raster map layer showing the cumulative cost of moving between
> different geographic locations on an input raster map layer whose cell
> category values represent cost.
> Keywords:
> raster map, cost surface, cumulative costs
> Usage:
> r.cost [-vknr] input=name output=name [start_points=string]
> [stop_points=string] [start_rast=string] [coordinate=x,y[,x,y,...]]
> [stop_coordinate=x,y[,x,y,...]] [max_cost=cost] [null_cost=null cost]
> [percent_memory=percent memory] [--overwrite]
> I have it running on my PC for r.cost.
> With a sed job I could substitute all
> module->description = ...
> by
> automatically.
> Maybe we could make a Web application to visualize the keywords
> like a navigatable tree or "TouchGraph" [1] or whatever appropriate.
> Any objections?
> Markus
> [1] Just as an selfish example (needs Java):
> http://www.citeulike.org/nocrawl/touchgraph_applet.adp?article_id=172900
> (double click on the floating objects to navigate)
