[GRASS-dev] Re: gis.m: resolution not preserved
Michael Barton michael.barton at asu.edu
Fri Aug 18 15:22:05 EDT 2006
Maciek,
I think that it's going from res=8 to res=30 as your extents go from 100x100
to 1000x1000 that is supposed to make it faster. The resolution is a
function of the extents. This code is only implemented (in 6.1 at least) if
you go into the explore mode. So that's why I'm trying to track your
problems better. I've done this, going back and forth between modes and can
only get it to change resolution if I'm in explore mode. I'll  keep looking
into it.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Fri, 18 Aug 2006 20:45:58 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass-dev <grass-dev at grass.itc.it>, Jarek Jasiewicz <jarekj at amu.edu.pl>
> Subject: Re: gis.m: resolution not preserved
> Michael Barton napisa?(a):
>> I posted a message on this over a week ago and got no reply.
>> <http://grass.itc.it/pipermail/grass-dev/2006-August/024866.html>
>> I also discovered this and thought it was a bug at first. But when I looked
>> at the code (this new 'explore mode' was developed by Cedric Shock), I
>> realized that it was intentional.
>> That is, it is dynamically changing resolution to speed display times as you
>> zoom in and out.
> A thought on this: how is switching from res=30 to res=8.29265653 (se my
> previous message) supposed to speed anything up? Did you miss something
> in my writing or is it me missing something?
> Maciek
