[GRASS-dev] hardcoded 'xterm': wrapper?
Glynn Clements
glynn at gclements.plus.com
Mon Aug 28 07:23:16 EDT 2006
Hamish wrote:
> > One minor point: I thought that using "which" was advised against, as
> > it isn't present on all platforms.
> On what platforms is it missing? If `which` is missing, what are the
> chances that other assumed unix tools are missing? (ie everything breaks)
I don't know, but SUBMITTING_SCRIPTS says:
5. If you search for a command in $PATH, do NOT
use the "which" command or the "type -p" command. Both commands are not
supported on all platforms, thus causing problems for some people. As an
alternative, please use code similar to the following shell script snippet
which will perform the same function. In this case, the path of the grass60
command is saved if grass60 is found in $PATH. This won't recognize aliased
command name.
# Search for grass5 command in user's path
for i in `echo $PATH | sed 's/^:/.:/
s/::/:.:/g
s/:$/:./
s/:/ /g'`
do
if [ -f $i/grass5 ] ; then
# Save the path of the grass60 command
GRASS_PATH=$i/grass60
# Use the first one in user's path
break
fi
done
If you must use "which", use as follows:
# check if we have awk
if [ ! -x "`which awk`" ] ; then
echo "ERROR: awk required, please install awk or gawk first" 1>&2
exit 1
fi
> > If it is used, stderr should be redirected to /dev/null, to silence
> > the errors about x-terminal-emulator not being found.
> On what platforms does `which` not return silence if the target isn't
> found?
The GNU version isn't silent:
glynn at cerise:6.1 $ which foo
which: no foo in (/opt/grass-6.3.cvs/bin:/opt/grass-6.3.cvs/scripts:<snip>)
