[GRASS-dev] hardcoded 'xterm': wrapper?
Hamish
hamish_nospam at yahoo.com
Mon Aug 28 23:40:06 EDT 2006
Glynn Clements wrote:
> > > One minor point: I thought that using "which" was advised against,
> > > as it isn't present on all platforms.
Hamish wrote:
> > On what platforms is it missing? If `which` is missing, what are the
> > chances that other assumed unix tools are missing? (ie everything
> > breaks)
> I don't know, but SUBMITTING_SCRIPTS says:
> 5. If you search for a command in $PATH, do NOT
> use the "which" command or the "type -p" command. Both commands
> are not supported on all platforms, thus causing problems for
> some people. As an alternative, please use code similar to the
> following shell script snippet which will perform the same
> function. In this case, the path of the grass60 command is saved
> if grass60 is found in $PATH. This won't recognize aliased
> command name.
> # Search for grass5 command in user's path
> for i in `echo $PATH | sed 's/^:/.:/
> s/::/:.:/g
> s/:$/:./
> s/:/ /g'`
> do
> if [ -f $i/grass5 ] ; then
> # Save the path of the grass60 command
> GRASS_PATH=$i/grass60
> # Use the first one in user's path
> break
> fi
> done
Yes, I was aware of that, but was ignoring it as it has been many years
since anyone reported an error with it and I never heard an explicit
example of a platform where it wasn't present.
fyi, I am responsible for adding this:
> If you must use "which", use as follows:
> # check if we have awk
> if [ ! -x "`which awk`" ] ; then
> echo "ERROR: awk required, please install awk or gawk first"
> 1>&2 exit 1
> fi
> > > If it is used, stderr should be redirected to /dev/null, to
> > > silence the errors about x-terminal-emulator not being found.
> > On what platforms does `which` not return silence if the target
> > isn't found?
> The GNU version isn't silent:
> glynn at cerise:6.1 $ which foo
> which: no foo in
> (/opt/grass-6.3.cvs/bin:/opt/grass-6.3.cvs/scripts:<snip>)
ok, so how about this:
> if [ ! -x "`which awk 2> /dev/null`" ] ; then
> 1>&2 exit 1
> fi
I found these messages in the archives:
http://grass.itc.it/pipermail/grass-dev/2001-April/009332.html
(supposedly missing on Cray & Solaris*)
http://grass.itc.it/pipermail/grass-dev/2001-April/009280.html
http://grass.itc.it/pipermail/grass-dev/2001-April/009350.html
[*] `which` was apparently missing on Cray & Solaris, but I think that
the test used in that first email is incorrect. In fact on my linux:
$ alias which
bash: alias: which: not found
$ type -p which
/usr/bin/which
so which is there, just not an alias. I'm still not convinced the
problem actually exists.
If we do need to use the `echo $PATH | sed..` method, I'd suggest
writing it as a small script (returning 0 or 1) and moving it to
$GISBASE/etc/ rather than cutting and pasting that ugly mess into
all the scripts that need it.
Hamish
