[GRASS-dev] Re: [bug #4905] (grass) gis.m: d.text.freetype does
not allow spaces in text
Moritz Lennert
mlennert at club.worldonline.be
Wed Aug 30 05:49:23 EDT 2006
Glynn Clements wrote:
> Moritz Lennert wrote:
>>> Is this fixed now? Freetype text doesn't work on a Mac so I can't tell.
>> No, neither the gis.m part, nor the d.text.freetype part (for which I
>> will post a separate bug report to make it more visible).
>> As Glynn wrote, the gis.m error can be "solved" by typing
>> d.text.freetype -n -b {text=Population totale}
>> instead of
>> d.text.freetype -n -b text="Population totale"
>> But I don't find this solution very intuitive, especially as on the
>> command line the second works.
>> So maybe there should be some treatment in gis.m which translates the
>> second version into something usable. Or at least the documentation has
>> to be updated, but I would only consider this as a temporary solution.
>> Just for memory, the d.text.freetype part of the bug is that even when a
>> space is accepted, it is not printed on the screen, making the above into:
>> Populationtotale
> There are two separate issues. gis.m has previously had problems with
> arguments containing spaces, but there have been some fixes in that
> area. If you come across this problem in the current CVS version, file
> a bug report.
That is what this bug report is actually about (what I call the "gis.m
part of the bug") and it is still open as of CVS-head from yesterday.
> The problem with spaces disappearing is that FT_Render_Glyph() returns
> an error for the space glyph, causing the code to ignore that glyph
> (and, significantly, not advance the rendering position).
But this only seems to be a problem with the current stable version of
freetype, i.e. 2.2.1. Using latest CVS code of freetype, the problem is
solved.
> The code should probably still advance the rendering position in the
> event that FT_Render_Glyph() fails.
Is this a problem with anything else then space ?
Moritz
