[GRASS-dev] Re: [bug #4905] (grass) gis.m: d.text.freetype does not allow spaces in text
Wed Aug 30 09:33:27 EDT 2006
Moritz Lennert wrote:
> > There are two separate issues. gis.m has previously had problems with
> > arguments containing spaces, but there have been some fixes in that
> > area. If you come across this problem in the current CVS version, file
> > a bug report.
> That is what this bug report is actually about (what I call the "gis.m
> part of the bug") and it is still open as of CVS-head from yesterday.
So the gis.m bug is still present? I.e. you can't include spaces in
the text?
> > The code should probably still advance the rendering position in the
> > event that FT_Render_Glyph() fails.
> Is this a problem with anything else then space ?
Probably not (well, it probably applies to all "blank" characters,
e.g. double-width space as well as the normall ASCII space character).
