[GRASS-dev] Re: [bug #4905] (grass) gis.m: d.text.freetype does
not allow spaces in text
Moritz Lennert
mlennert at club.worldonline.be
Wed Aug 30 06:08:06 EDT 2006
Hamish wrote:
> William Kyngesburye wrote:
>> Do you know what fonts you were trying to use that didn't work? Most
>> of the common fonts that come with OSX are dfonts (Apple's fonts) and
>> suitcase TT fonts (the M$ fonts). There are a few unix-style .ttf
>> fonts in the system (but those tend to be other language script
>> fonts), and some OTF Japanese fonts.
>> X11 vs Aqua shouldn't affect freetype itself. Though if you use
>> Apple's X11-bundled freetype, I found that suitcase font support is
>> disabled there, and only dfonts and unix-style fonts work.
> Hi,
> just testing d.text.freetype on GRASS 6.3 (including just-now fix from
> Glynn for main.c) I'm still getting a crash (SIGFPE) if the text=""
> contains a space. The debugger traces it to this call in main.c (line
> 1040).
> if(FT_Render_Glyph(face->glyph, ft_render_mode_mono))
> i.e. it breaks within FT_Render_Glyph() if ch=32; it doesn't make it as
> far as Glynn's new code (the next line).
> in the terminal:
> Floating point exception
> Monitor <x0>: Premature EOF
I cannot confirm this error on Debian testing with libfreetype6
2.2.1-2. For me Glynn's fix works.
I do however have (unrelated) problems with accented characters. From
the first accented character onward, nothing is displayed, i.e
Densité de la population
becomes
Densit
I'll file a report on that.
Moritz
