[GRASS-dev] Re: [bug #4905] (grass) gis.m: d.text.freetype does
not allow spaces in text
Glynn Clements
glynn at gclements.plus.com
Thu Aug 31 09:03:44 EDT 2006
Hamish wrote:
> > Done. As well as all of the environment variables understood by the
> > PNG driver, immediate rendering now supports:
> > GRASS_FONT
> > GRASS_FT_FONT
> > GRASS_FT_ENCODING
> > corresponding to the stroke font, FreeType font and encoding for
> > FreeType fonts. If both GRASS_FONT and GRASS_FT_FONT are set, the
> > latter takes precedence; if neither are set, the "romans" stroke font
> > is used.
> Are these shell variables or g.gisenv variables?
Environment variables.
> If they will be set from a GUI window, do they need to be g.gisenv
> variables?
No. They would be set the same way that PNG driver variables (e.g.
GRASS_WIDTH, GRASS_HEIGHT etc) are set.
