[GRASS-dev] grass63 -text startup screen
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Aug 30 09:57:49 EDT 2006
Hello Maciek
I suggested some improved text a while ago:
http://grass.itc.it/pipermail/grass5/2006-July/024686.html
There were no objections - I will commit this if there still are none.
Paul
On Wed, 30 Aug 2006, Maciej Sieczka wrote:
> Hi,
> Grass text startup screen says:
> LOCATION: This is the name of an available geographic location.
> -spearfish- is the sample data base for which all tutorials are written.
> This is not true and incomplete. How do I correct it? I suggest:
> LOCATION: This is the name of an available Grass location
> (data set). "spearfish" is the sample data set for which many
> tutorials are written. You can obtain it at http://grass.itc.it.
> OK?
> Maciek
> P.S.
> http://grass.itc.it/download/data.php contains:
> GRASS locations (databases)
> Let's not mix location and database. I think it could be:
> GRASS locations (data sets)
> instead.
> Maciek
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
