[GRASS-dev] invoking d.vect and d.rast from CLI
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 31 16:07:15 EDT 2006
On Thu, August 31, 2006 20:15, Patton, Eric wrote:
> I'm having trouble getting d.rast and d.vect working on the command line.
> Here's a step-by-step to reproduce using Spearfish:
> After initial Grass 6.3 startup finishes:
>>d.mon -L
> name description status
> PNG Create PNG Map not running
> png1 Create PNG Map not running
> png2 Create PNG Map not running
> png3 Create PNG Map not running
> png4 Create PNG Map not running
> png5 Create PNG Map not running
> png6 Create PNG Map not running
> png7 Create PNG Map not running
> gism Create PNG Map for gis.m not running
> x0 X-windows graphics display not running
> x1 X-windows graphics display not running
> x2 X-windows graphics display not running
> x3 X-windows graphics display not running
> x4 X-windows graphics display not running
> x5 X-windows graphics display not running
> x6 X-windows graphics display not running
> x7 X-windows graphics display not running
> # Shouldn't gism be shown as running here?
No, since last week, gis.m uses Glynn's implementation of monitor-less
renderning via the GRASS_RENDER_IMMEDIATE variable.
> ~ >g.region rast=elevation.10m
> ~ >d.rast -o map=elevation.10m
> 100%
> # Nothing draws in the gis.m map display!
> # Let's try a vector instead...
> ~ >g.region vect=soils
> ~ >d.vect soils
> Again, nothing displays.
> Any ideas on what's going on here?
Try rendering without launching gis.m. Check if GRASS_RENDER_IMMEDIATE is
set to true.
However, I don't know if when it's set, it will render to the same ppm
file as gis.m.
Moritz
