[GRASS-dev] r.resamp.stats error
Fri Dec 1 19:04:41 EST 2006
Martin Wegmann wrote:
> I found a weird behaviour in r.resamp.stats which causes a shift of the
> resulting image but only on a large scale (subcontinental scale, shift to
> south-west).
> I tried to reproduce it with the spearfish dataset but failed.
> Doing it on Africa srtm DEM (res based on gtopo30 DEM):
> g.region -g
> res=0.00083333
> g.region res=0.0083333
> r.resamp.stats input=dem output=dem_resampstats method=average
> produces this output of a small region with islands shown in the jpg (overlay
> with original raster)
> any idea how to fix this? regards, Martin
Odd. Can you provide the exact commands, including import and
region-setting? (I have all of the gtopo30 files).
