[GRASS-dev] configuring grass 6.3 for cross compilation
Glynn Clements
glynn at gclements.plus.com
Sat Dec 2 05:54:06 EST 2006
Glynn Clements wrote:
> > Are there any updates on how to configure 6.3 for cross compilation?
> > Any help will be greatly appreciated!
> Right now, you can't. I'm looking into a fix, but until then you'll
> need to manually remove the check from the configure script.
I've committed a change to the configure script which should fix this,
although I don't a cross-compilation environment to check it.
