[GRASS-dev] configuring grass 6.3 for cross compilation
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Sat Dec 2 06:38:03 EST 2006
Ok, it works now. Thanks, Glynn.
>>> Are there any updates on how to configure 6.3 for cross compilation?
>>> Any help will be greatly appreciated!
>> Right now, you can't. I'm looking into a fix, but until then you'll
>> need to manually remove the check from the configure script.
> I've committed a change to the configure script which should fix this,
> although I don't a cross-compilation environment to check it.
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
